Certain .MOV files don't play
Lurksponge
Brand new PC, Windows 7 Pro with great specs. I've installed the DXV codec and Resolume Arena 5.0.1 and while the visuals it comes with and visuals from DocOptic load successfully, other .MOV files from other vendors like MotionLoops do not load at all (they DO play in Windows Media Player, so I'm not sure if it's a codec issue). I've tried re-downloading the files and installing quicktime but nothing seems to work..
Lurksponge
Re: Certain .MOV files don't play
Installed FFDShow and took the default codecs, still nada. Plays in windows media player but not Resolume 5.0.1
Did you also installed Quicktime on your computer? If not...do it
Greetings
Greetings
Do you like outlines? Easy Outliner on Juicebar Re: Certain .MOV files don't play
What codec are your .mov files?
