Resolume Arena 5.0.1 crash when send video on Second display
mihaylovpetko
Hi , I use the Asus Rog G752VY-GC100T with Resolume Arena 5.0.1. When I try to send Output Monitor to an external display Resolume crash (Not Respond) and announces to close it . When I move the main program window to the secondary display and use the laptop display to Otput Monitor there is no problem .
Jani Kormu
Re: Resolume Arena 5.0.1 crash when send video on Second dis
same computer and same problem.
According to a similar thread on FB, apparently this is fixed on the 5.0.2 release.
Does that solve the problem for you as well?
mihaylovpetko
No I still have a problem. I instal Arena 5.0.2 but did not uninstall Arena 5.0.1. Now I have two installed program. And two version have the same problem.
mihaylovpetko
I have success. Uninstall Win 10 Home and install Win 10 Pro, then install only video drivers from Asus Rog site.
Re: Resolume Arena 5.0.1 crash when send video on Second display
Hi there. Had the same issue. Problem is some driver pre-installed by Asus. The trick is to install a fresh version of windows, does not need to be pro. It worked for me with Home version.
Cheers !
Cheers !
