Import projects from Res4 to Res5
violadd
Post by violadd »
Import projects from Res4 to Res5. This is real? I have many projects for theatre in Res4. How can I import projects WITH mapping from Res4 to Res5.
pfelberg
Re: Import projects from Res4 to Res5
Post by pfelberg »
Just go to your R4 compositions directory and copy them all to R5 composition dirirectory.
On windows, go to users/documents/.... you will find them there.
I am afraid that mapping information (advancend output) is not stored within each composition.
Paulo
violadd
Post by violadd »
I need MAPPING from Res4... Files found, done "fixed all". Ok. But I need mapping more then files. Really no ways?
Unfortunately, the coordinate system and rendering pipeline had to change so much on the new version, that it was not doable to convert old presets to the new system anymore.
With all the new zoom and snapping options, you should be able to do your mapping a lot quicker in 5 though. Maybe that eases the pain a little bit?
