video sign spliter
video sign spliter
i was wounder if any one knew if there is a video signle spliter that splits the signle over more then one screen?
there are some hardware devices to do that, but they are very expensive (>3000Eur). If you need links tell me.
I tried to build one myself, but it can't be done in pure analog (timing problems). You would have to digitize the VGA/video signal and then read out the right lines for each monitor, from an double buffered video ram.
If i stumble cross a cheaper solution i will post it here, but it is unlikely.
the name of the device what you are looking for -as I understand from your note- is video matrix switcher
it works like this
you have lets say 4 video inputs and 4 video outputs
you can route lets say video input 1 will go to output 1 and 4
video in 2 will go to out 2 and video 3 in will go to out 3
or how as you wish...
it is very easy to use
there are total of 8 buttons 4 for in and 4 for our
just select the in channel to go where...
is it what u want?
it works like this
is it what u want?
Anonymous
Anonymous
