Video Clips not loading
visualmapper303
Post by visualmapper303 »
Hello everybody,
I'm having issues on my Windows 10 machine loading video content. I load the video folder in the resolume browser, but neither a preview of the video or anything loads. When I try to drag and drop the clip onto a track it doesn't load onto the deck. I have resolume installed on a SSD with my OS and the video files are on a separate internal drive inside my tower. Also should add that the demo project loads fine and all the videos in the deck play, I just can't drag and drop my own clips into a session.
Any help appreciated, thank you.
Re: Video Clips not loading
what kind of video files are those? format/codec
visualmapper303
They are .mov files, they work perfectly fine on my macbook pro but not my PC.
AdevProjects
Post by AdevProjects »
Make sure you have quicktime installed.
visualmapper303
Ahhh! I knew it was something simple like that... I just didn't find the answer in any of my research. Wanted to work on a bigger project that's more CPU/GPU intensive on my Desktop PC.
Thanks a lot for the response! :D Much appreciated.
