Ok I just want to know the best way of setting this up, I'm using:
1. imac mid 2011model
2. 1 HD Camera
3. 1 Projector that supports VGA, s-video & composite
Up until recently I've been using the edirol v4 to connect all this together, but now i want to be able to connect my camera to my computer and so I have full use of the effects in Avenue, then out to my projector and onto the screen.
I was looking at the black magic intensity shuttle but it appears it doesn't support output from a computer to projector ?
I basically just was to replace the V4.
thoughts?
Help with live show setup
Re: Help with live show setup
In your set up you'd use the BMD for capture only to get the camera signal into Resolume then you send the output from Resolume to your projector using your GPU.
