hi,
i am using my mac book pro to run resolume arena for a show being control by the grand ma
my mac spec are 16gb of ram 2.2 ghz intel core i7 intel iris pro 1536mb
running os x el capitan
is this stable ? also the software kept crashing what can do ?
any ideas ?
									Mac-book is it stable
				jacktechtheatre
Jack Homer
Live Visual Production Technician
Resolume Arena 4
System- MBP Mid 2014,
OSX- El Capitan
Ram- 16Gb 1600 MHz DDR3,
Processor- 2.2GHz Intel Core i7 ,
Graphic- Intel Iris Pro 1536MB
Resolume Arena 4
OSX- El Capitan
Re: Mac-book is it stable
If your MBP only has the integrated GPU, you won't be able to do much.
It's probably crashing because it doesn't have enough video RAM to render your comp so make sure all your files are in DXV3 codec even for 1-frame files.
				jacktechtheatre
all my files are in that format
									Jack Homer
Resolume Arena 4
OSX- El Capitan
Resolume Arena 4
OSX- El Capitan
Your MBP only has the integrated GPU, right?
How big is your comp and how many layers/clips do you play at the same time?
