RAM
bottleneck
hey ecin!
how much ramm do u have at the moment?
anyway, for smoother playback it would be better to get faster harddrives or even a RAID, if you want to have smoother playback speed! (btw: fastest hardrives are the WD RAPTOR @ 10.000rpm)
trm
trm
goodquestion
hello again!
i believe, that your RAMM should be sufficient for resolume.
what other specs has your laptop?
resolution and codec of your clips?
external RAID drives ... pretty good question .... i once read about some geeks, who stripped 4 iPod Shuffles into a RAID, so I guess this most be possible as well.... don't know, if it makes sense though.... maybe u should ask that question on vjforums.com
take care
trm
take care
trm
resolutions
it is pretty decent indeed. i wish i could afford an inspiron too...
therefore, i am really suprised, that you are experiencing problems, although u are working with flashfiles only.!
what process resolution are you working with?
what resolution are your flashfiles?
i think, the process resolution should match your footage resolution for best performance...
