APC 40 " make sure this port isn t......
LEOO
Post by LEOO »
HI,
My APC40 works fine during a long time with resolume 4.1, but since 4 days no works:
" make sure this port isn t used by any other application".
no other app is on.
i ve changed the APC on the 4 usb ports, idem
reboot, idem
the akai is ok on the configuration panel,
and the apc works very nice with Live 9 and Cubase.
what else?? i m confused
i find a post same prob with a nanokorg but no solution
win10/i7/
enchanté from paris
Re: APC 40 " make sure this port isn t......
Can you contact us directly with your log file, please? You can do this really easily by clicking the 'Feedback' tab in Resolume's preferences.
