Audio Input from 2nd PC
jubi
Post by jubi »
is it possible to setup audio input from 2nd pc? so it would be work like that:
1st PC + controller (mixer with serato software) > cable connected to 2nd pc as input > video mix on 2nd pc but with audio from 1st pc.
I cant find INPUT settings to set it as line 1 input (or however its called), could you help me?
Re: Audio Input from 2nd PC
So if I understand correctly, you have a cable from PC1 output to PC2 microphone input, correct?
If that's the case, go to Arena>Preferences>Audio and under External Audio FFT Input, select the right input and adjust the gain as needed. Then you can use that input to control effect by choosing Audio FFT>External.
If you would like to mix the 1st pc's audio in resolume, or do some effects on it, I think there is no built in plugin, or source that handles the audio stream.
