hi all
we are trying different low-end laptops to see which one can run a simple single-screen resolume in in installation. We had good results with other brands, but this (used) hp envy x2 crashes right at start.
We tried 4.2 and 5.2 in both W10 Home and W10 Pro.
can anyone tell me anything?
i tried to remove the config.xml bith there is none..it doesnt get that far. I tried putting there one but that did not helped either.
Thank you
Balazs
