Arena 5.0.4 Prefs panel resets all layer A / AV / V levels.
Pretty much as subject. Using Arena 5.0.4 with audio controls viewable. 5 layers.
When opening preferences it resets the levels to defaults.
theLABVisuals
Re: Arena 5.0.4 Prefs panel resets all layer A / AV / V leve
could you tell more about your system where you are experiencing this?
maybe upload a screen recording on how to reproduce.
theLABVisuals
Of course.
MacBook Pro retina 15" amid 2015
2.8ghz i7
16 gig ram.
AMD Radeon R9 M370X 2048mb.
I'll screen shot later.
2.8ghz i7
16 gig ram.
Re: Arena 5.0.4 Prefs panel resets all layer A / AV / V levels
I think this may have to do with your connected midi controller.
When opening the prefs panel, Resolume polls the USB ports for connected midi controllers. Controllers like the APC40 will respond to such a poll by sending out their fader states. So when you have anything mapped to these faders, the values will update accordingly.
I think it's a pretty nifty feature, because it makes sure your UI state matches your controller state. I wish more controllers would do this.
theLABVisuals
It's not a feature I've noticed in any of the older releases of Arena I'll be honest
I'll check once again and record a screencast if it's continuing.
