Hi, resolume automatically sets the dimension of clips to 320x240 when recording a session.
How can i change that? 320x240 is far too small for a beamer, the quality sucks.
I need at least 720x5
other probs:
-sometimes when i click on a deck to load, it stops loading it in the middle of the process and u can see those clips, that where in the deck, that was opened before.
-when i drag&drop a effect to the effect slot, i is automatically set to 100% - how can i change that?? I want to config the effect before i activate him!!!
Thx, Julow
800x600 recording possible?
you have click the screen setup button to change the screen details. as always RTFM...
afaik, the deck problem is fixed, and the next version of resolume to be released shortly will have it working properly.
you can make so that a midi keyboards velocity changes the opacity of the effect. but i dont think it can be done with drag and drop, or the computer keyboard.
