NO AUDIO PLEASE HELP!
So I'm new to VJing and video editing software in general but for the most part I figured out most of the problem I ran into...but sadly one BIG issues remains for me...I can get any kind of audio(Including the sample ones) to play. Video works fine just audio for anything except the resolume robo voice doesn't work. Iv tried taking my audio files and converting them to .wav even tho the sample sounds don't work ether. Iv tried to download ASIO4ALL and followed the instructions on how to put it as my output audio and I change the input audio to my headphones(turtle beaches)...still nothing...Iv checked if anything was muted ether PC wise or software...nothing. I really need some help here because I have a project coming up using this software but if I cant get audio to work its gonna kill the project. Also I'm not sure if the Inputs and Outputs are set up correctly so if anything could also explain what options to put into the audio input and outputs that would help too. Thanks for reading sorry its long I just wanted to explain solutions iv tried that have failed.
Re: NO AUDIO PLEASE HELP!
I'm assuming you can get audio out of your computer using other software, right?
Can you share one of your comps with an audio file that doesn't work? Make sure you attach the audio file as well.
Ill be honest and I apologize for anyone looking for a solution but somehow when I restarted my computer and re opened it along with changing my audio back to my head phones it somehow plays music now....the next problem I'm having is that the music I play back is ether speed up or slowed down and I never changed the file to do that...and when I play it back on anything other than Resolume its fine but when I play it in Resolume is ether speed up or slowed down..is this because I don't have the full version?
No it's probably because your files are in BPM rather than Timeline.
Click on Arena>Preferences>Defaults and make sure both your video and audio clip transport modes are set to Timeline, then reimport the files and it should be playing at the right speed.
Sorry once again fixed the problem...it seemed when I converted the .mp3 file to a .wav it changed the BPM's to a very high and very low level. I have no idea why but I adjusted the BPM's accordingly and it is good to go. Thanks for reading
@Oaktown Ahhh I had no idea I could do that to haha... I'm new at this so I'm trying to figure everything out. Next audio file I have ill do that so I wont have to sit there and adjust the sound <3
