chunky video playing even in low resolution footage
djekip
Post by djekip »
hey all need a quick advice.
what might be problem with our resolume server. We got new tv to output material and now everything is realy badly videos hangin and everything is realy cheesy.. even when outputting just same picture on every screen beside the old setup wich we runned 4 screens sliced 7620*1080 picture to them as videowall..
i updated my videodrivers and nothing helped..
our system
Resolume arena 4.2.2
i5 16GB with 2 SSD driver
2 GTX960 videogards with 2g memory each
6 hd screens 5 to output and 1 on interface..
any advice would be helpfull
-Eki-
Re: chunky video playing even in low resolution footage
This is a large composition and your computer is only an i5 processor. Are you using DXV3 codec for all your movies?
Also, you're using two 2GB GTX960 GPUs which are not very powerful cards to begin and you're adding an extra load by outputting from 2 GPUs.
You might be better off using a MATROX TH2G to get 5 HD outputs from one GTX960 by splitting one output in three rather than using the two GPUs.
