i'm searching for a solution to stream the arena output into the citp protocol. i need this for visualisation and preprogramming with grandMA 3D.
i found a tool which is currently in development: http://www.theimpersonalstereo.com/citpsharp/
is there any hint when resolume is going to add the citp protocol? or do you know any workarounds? maybe streaming via syphon/spout into vvvv and converting into citp? maybe there is someone out there who can patch this in vvvv for us?
CITP Stream
Re: CITP Stream
I'm working on an app called CITPLink, which is an implementation of the CitpSharp library in a standalone application which can be used to share Syphon/Spout streams as CITP sources. Will be available in a couple of months.
Re: CITP Stream
omg, this sounds amazing! could you share it in this thread when it is ready?
and if you need help we can alpha/beta test and give you feedback
we are running resolume arena media servers linked to a grandMA2 fullsize with MA3D
Re: CITP Stream
they've said in a previous post that they are waiting till Resolume 6 to implement all the features used by LD'sFischmaster3000 wrote:i'm searching for a solution to stream the arena output into the citp protocol. i need this for visualisation and preprogramming with grandMA 3D.
Jayme McColgan
Lighting Designer
Lighting Designer
Re: CITP Stream
To be completely clear, what we said was that CITP is only one of the many things that would be needed to make Resolume work like a media server that LDs are used to. Whether or not we're going in that direction for Resolume 6 is a different question entirely.they've said in a previous post that they are waiting till Resolume 6 to implement all the features used by LD's
Resolume wouldn't be what it is today if we wanted to make it another Hippo / Arkaos clone that approaches video as if it's just a glorified fixture with fancy gobos.
Video and light share a lot of similarity, but they are not the same. The popularity of Resolume with LDs, despite the obvious lack of CITP and a UI that compliments a lighting desk workflow, shows that maybe running video on modern stages requires a different approach than the servers of old.
Re: CITP Stream
sorry joris but I think that is an excuse.
I feel primarily about anything from a wound of control.
because unfortunately the preview my clips is necessary. why it is not possible in resolume is probably rather a technical problem.
hopefully you chased you not professional ld´s by this rejection.
Re: CITP Stream
On OS X you can use CITP Tool: https://k-mt.net/citp-tool/
This application supports CITP streaming from Syphon Sources and also nearly all other applications, which will be displayed on your monitors.
A free of charge demo version is also available.
Re: CITP Stream
impsnldavid wrote:I'm working on an app called CITPLink, which is an implementation of the CitpSharp library in a standalone application which can be used to share Syphon/Spout streams as CITP sources. Will be available in a couple of months.
hello!!! some new about CITP for vvvv or spout? Thanks
Re: CITP Stream
alenokia wrote:impsnldavid wrote:I'm working on an app called CITPLink, which is an implementation of the CitpSharp library in a standalone application which can be used to share Syphon/Spout streams as CITP sources. Will be available in a couple of months.
How is this software coming along???
Re: CITP Stream
Is CITP steel on the to do list?
