Do you think its better to use two graphic cards of the same model, like two GTX970s?
Plug both TH2GOs into the main card, or one for each card?
Would it be better to invest in a better card for the load, like a Titan X, or the new 1080 even, plug in two TH2GOs, and add another cheaper card just for the last four outputs?
Which card would you suggest for the second one?
Thank you for any information.
