p.s. Also NVIDIA thinks Resolume is Total War
NVIDIA settings
- rawdesigns
NVIDIA settings
which settings is best for performance for Resolume? I have everything set for max performace but not sure about other bits like "Negative LOD bias". Thanks!
Re: NVIDIA settings
Interesting! Can you tell me all settings? How did you decide these? Did you get it somewhere?
Re: NVIDIA settings
I adjusted Nvidia settings in order to achieve max performance possible.
Ambient Occlusion: performance
Anisotropic filtering: off
Antialiasing - FXAA: off
Antialiasing - Mode: off
CUDA - GPUs: all
Maximum pre-rendered frames: 4
Multi-display / Mixed GPU acceleration: Multiple display performance mode
Power management mode: Adaptive
Shader cache: on
Texture filtering - Anisotropic sample optimization: On
Texture filtering - Negative lod bias: Allow
Texture filtering - Quality: High performance
Texture filtering - Trilinear optimization: on
Threaded optimization: Auto
Triple Buffering: on
Vertical sync: on
Virtual reality pre-rendered frames: 4
I think this settings are correct, but I have no idea what are for some settings, please tell me if these values are correct.
CUDA - GPUs: all
Shader cache: on
Vertical sync: on
