Hello, I need sometimes a tip.
If I set Resolume with 3 monitors,
two of them as a video output,
later the computer reboot and the first monitor remove or reposition.
Then start Resolume with the video screen output to the pre-assigned Montoren.
How can I make it, starts the Resolume without screen output?
How can I let the program show on the right monitor.
PS:CTRL + SHIFT + A or CTRL + SHIFT + D for output / Advanced I remember not so much.
I can change it either.
thx
Resolume, the program switch to montor, or screen output off.
- RycoDePsyco
