Hello,
I try to connect resolume v4.0 with GradnMA 2 Lite
Can I get step-by-step instructions on how to have it done by Art-Net?
I have:
Settings GrandMA:
IP Ethercon 2: 2.168.12.20
Resolume address 10.001
Network Protocols; Network: 1; Subnet: 0 Universe: 9
Network DMX if Alone - on, Art-Net Output Active- on
Setting PC network card (TCP / IPv4)
IP: 2.168.12.21
Mask: 255.0.0.0
Setting Resolume; DMX Preference:
On DMX Input
Subnet: 0
Input Port: 1
Connect Resolume v4 with GrandMA 2
Re: Connect Resolume v4 with GrandMA 2
For version 5, the instructions are as follows:
Set up a network router with 2 network cables :
-one running to the GMA2 Artnet port
-the other to the computer
Set the IP of the GMA2 to 2.0.0.1, subnetmask should be 255.0.0.0
Set the IP of the computer to static and to something in the 2.0.0.X range, for example 2.0.0.10, subnetmask should be 255.0.0.0 (matching the setting in GMA2).
Set your Artnet universe in GMA2 to subnet 0, universe 0 (or whatever your first available output is).
And in the DMX tab of the Prefences of Resolume, create a new DMX input. Set it to Art-Net, with the same subnet and universe as you set in GMA2.
