Touch Screen Recommendation?
Digitrevx
Post by Digitrevx »
Hello
I'm interested in a touch screen for Resolume with HDMI / DVI input. Looking for something with good viewing angle and good sensitivity / response. I'm wondering if anyone has had good experiences with a particular brand or model.
Re: Touch Screen Recommendation?
Ive used the Acer T231H for a while. It works with infra-red tracking. I've choosed it because of its good tilt ability. It's outdated now...but you may be able to shoot a used one for some bucks.
Keep in mind that scrolling the clip deck of Resolume can be pain in the a** because of the small scrollbar.
greetings
Digitrevx
Post by Digitrevx »
Thanks a bunch and yeah I can bet scrolling is rough. I'll figure out something.
I'm going to try to grab something in 2 weeks.
I've been using the divide beat button on particular clips a lot lately for quick build ups before drops.
The button is so tiny and I'm not sure how to map it yet since its a option only available at the clip level.
jaydeeshow
Post by jaydeeshow »
Hi Digitrevx,
I was wondering if you sticked to Touch Screen monitor, or upgraded?
Now are definitively more reliable and accurate.
Best,
J.
