Key board latency?
Digitrevx
Key board latency?
Post by Digitrevx »
Perhaps I'm overlooking something. I'm keyboard mapping at home for a show without my controller.
I'm noticing on clips with no BPM sync enabled and the transition slider at 0 there is considerable latency / lag between the time I hit the physical key on my keyboard and the clip is selected and played.
I can visually see the latency in which the clip is even selected.
When I mouse click the clip it triggers immediately like I'm looking for. Is there something I'm overlooking?
Also unrelated but pains never the less, very sad the twitch effects are very broken with all its translation effects. ><
Cheers
Re: Key board latency?
Twitch is unbroken again in the 5.1 update.
How big is your deck? How many columns, including empty ones? How many layers?
Digitrevx
Post by Digitrevx »
About 230 columns 7 layers right now since its WIP.
Digitrevx
Post by Digitrevx »
Sorry for double post. I've tested on my controller and the latency is almost unnoticeable. Perhaps it's a hardware problem with my keyboard. (logitech g19)
I have a logitch g13 in a box I kinda wanted to try in parallel with my midi but it might suffer the same way my keyboard is.
