Midi Mapping - Composition tab
mfo
Post by mfo »
just a small one:
When going into Midi Mapping the tab in the first properties panel jumps from Composition to Layer. It never stays with Composition properties. At times, i.e. when finetuning your Midi Map of Composition effects, that can be really annoying. (Of course one can deactivate Layer properties, but I usually use them..)
Would be great if the opened tab stays open for midi/key/osc mapping.
Thanks,
Marcel
Re: Midi Mapping - Composition tab
You can change the view to display all 3 panels. Then once you're done finetuning, you can switch back to the 2 panel view.
mfo
Post by mfo »
ok, that's another work around. yet it would be great if the opened tab would simply remain.
