Log Sheet of Files played
uditbpatel
Post by uditbpatel »
Hi
Is there in way of generating a log sheet of the files that have been played out with a time-stamp along with the file name.
Re: Log Sheet of Files played
Sorry, that's not possible.
Theoretically, someone who's handy with OSC and creating small apps could make an app for you that does this. Ravensc, are you busy this weekend? :D
In about two weeks I'll have time to look into it, but no promises.
do you have the composition saved, or is it a live assembled performance - is the composition changing during the show?
ravensc wrote:In about two weeks I'll have time to look into it, but no promises.
ok, so looks like this doesn't matter much if you don't want full path or file extension :)
do you have something like this in mind?
(deck switches will probably be handled as clip stop events)
uditbpatel
Yes this is what is required for the log sheet :) .'
In the autopilot mode does it log the deck switches as well?
Thank your racensc/Joris for the help
uditbpatel
The composition will not be changing during the show.
uditbpatel wrote: The composition will not be changing during the show.
you can download the program from http://palffyzoltan.hu/?url=controller. try before buy ;)
Set up the Resolume client connection in preferences to send and receive OSC from Resolume, and enable clip logging.
Open your composition to get full file paths in the log for the clips (only available for the Master).
You'll find the logs in Documents/Controller ClipLogs/ , they are tabbed txt files.
uditbpatel
This is what i required ,try before you buy :D
