SVG export
rawdesigns
SVG export
Post by rawdesigns »
love the new update!
I was wondering how to get those paths directly into after effects after loading the SVG into illustrator. Thanks!
Re: SVG export
rawdesigns
Re: SVG export
I figured this out.
1. load the svg into illustrator
2. select all paths in illustrator and copy
3. in after effects load the same amount of paths into your shape layer as you have slices
4. paste
also figured out how to stroke the paths.
- add offest paths above trim paths which is above stroke paths
this keeps the paths inside the stroke so they don't bleed onto other slices
Re: SVG export
Look at the link I posted, it should be much quicker in CC/CS6.
rawdesigns
Re: SVG export
Joris wrote:Look at the link I posted, it should be much quicker in CC/CS6.
ah much quicker! thanks!
