Round lumiverse. How to make?
Hi everyone! For example, if I have round shapes on the stage and I want to use dmx led strips for this shape is it real to make settings for round lumiverse? I try to make it in Avenue but there only line lumiverse...
Re: Round lumiverse. How to make?
I think this way will be a problem if you will have for example 30 meters led strips 60 lamps per meter in your stage project and all round shape. Make pixel by pixel mapping it is crazy way.
I'm sure it would be easier to have the built-in option to make circles of any size, but it's not available yet so you should make a request for a new feature.
In the mean time, even though it may not be the fastest way to build your stage project, at least you can get it done! And since you can copy and paste even between lumiverse it should be pretty quick once you've done it a few times!
