I upgraded to 5 a week or so ago, and discovered that no spout input will play. Arena will see the input as a source and I can drop it on a clip, but the clip is blank. Tested with 4 different videos apps with spout.
Spout in 4 was working fine, until around the time I updated 4 to the latest version. Now both versions act the same- they see all the available spout sources, but none of them will play. No preview, Just blank. Running off a new Lenovo laptop, discrete NVIDIA video card. It's not a scaling issue, I've looked at that. Anyone else have this issue? Thanks in advance.
No Spout input on Arena 4 or 5
Re: No Spout input on Arena 4 or 5
Are you using the FFGL Spout plugins, or the native Spout sources that were added on Avenue 4.5 / Arena 5?
Most likely an Optimus problem if the laptop has it. Disable the integrated Intel graphics in the NVIDIA control panel or BIOS if you can and see what happens.
