Connecting or Merging Clips
Chimera216
Post by Chimera216 »
Hello everyone,
I have clips with both audio and video and was wondering if I can merge 3 clips into one clip. I would like to make each 10 minute clip into one long 30 minute clip. So that the next one can play immediately after the first one ends. Is this possible? I tried using the recording button but that removed the Audio from it. Thanks in advance for anyone's help.
Re: Connecting or Merging Clips
Put these clips into one layer then set auto pilot to 'Play next clip' (right click on clip) for the first two clips,
if you set this for the third clip too then the playback will jump to the first clip in the layer when the third clip ends.
Now you only have to launch the first clip to get things going.
