Free OSC Controller
Shaun
Free OSC Controller
Post by Shaun »
Hey,
I made a little controller for resolume using OSC. The main reason I built this is to have the ability to change the transition type between selecting clips. It works by saving certain parameters (like x position, scale, clip etc) in presets and interpolating between the values.. You can move layers around by recalling presets and also make a loop with the timer function..
----> Could have many bugs.. only works on windows.. currently supports 4 layers with 8 clips..
Put it up for free download here -> http://www.filedropper.com/rescntrl
Let me know how it goes..
Shaun
