Slice Border & Fill Effects
ckombo
Post by ckombo »
Please (I'm begging) add some border stroke and fill effects for slices. These could include parameters like; for stroke: colour, Stroke Amount (%), Dashes, motion (clock wise/counter clock wise), speed; for fill: colour, opacity, Amount (%), Direction/type (up/down/left/right, center horizontal/vertical).
These features are available on HeavyM and maybe other applications.
Cheers ;)
drazkers
Re: Slice Border & Fill Effects
Post by drazkers »
Check out the export to SVG function.
Now you can easily animate all of that in After effects! With all your slices sorted and with DXV3 GPU acceleration.
