Copy/paste clip properties
elgarf
Post by elgarf »
Hi.
I think this is very time-saving feature, when you need to create some clips with same properties, but can't use layer properties.
Re: Copy/paste clip properties
....Abracadabra :) ....it's already there!
- Copy your clip with the config you wanna use with other clips inside the clipdeck.
- Trigger the copied clip
- Drag'n'drop the new footage on the little clip thumb inside the clip properties.
Properties stay....footage change.
Greetings
elgarf
Post by elgarf »
Yep, but what if I want put 5-10 clips, select them all and paste properties?)
I am totally with you that "rightclick - copy - multi select - rightclick - paste clip properties" is a faster way. But I guess...for now - that's the way to go. Luckily 5-10 clips aren't that time consuming.
Best wishes
