advanced output kill the output/preview
VjLuper
Post by VjLuper »
hallo guys!
I'm trying to install resolume on a win7 computer with an AMD FirePro™ W600 graphic card
everything works fine till the advanced output is on "virtual device".
but as soon as I switch it to one of the display, the output monitor and the preview monitor stop to works
same thing happen if I set the output to fullscreen (but not if I set fullscreen in my principal monitor)
any idea how to solve this?
drazkers
Re: advanced output kill the output/preview
Post by drazkers »
The w600 is a pretty weak card but it supports openGL so you shouldn't have an issue with that.
Sadly amd drivers do alot of funny stuff, i always had alt tab make resolume blink several times when i had a 7970.
I would try several generations of drivers, usually you gotta look for the sweet driver version with resolume and AMD.
VjLuper
Post by VjLuper »
do you mean trying to install other than the last driver version?
do you know where I can found them? i did some research, but till now no luck!
I found only the last version: http://support.amd.com/en-us/download/w ... pro-driver
Yes, AMD drivers are notoriously buggy and it can be a hit or miss relationship with Resolume!
When you click on the link, you'll see on the left of the screen a link for "Previous FirePRO/GL/MV Drivers and Software" and here it is just in case you don't find it:
http://support.amd.com/en-us/download/w ... 07%20-%206
VjLuper
Post by VjLuper »
hey this is weird. I tried using an external monitor instead of projector, and it works cool.
Problem is just with the projector, make any sense for you?
drazkers
Post by drazkers »
Yes, sounds like weird drivers. AMD would do wacky shit to Resolume like that for me.
We haven't heard of any problems on single AMD cards for a while. To be honest, I doubt this is a driver issue.
Have you checked your Windows Desktop Scaling and made sure it's set to 100%?
Scratch that. I re-read the original problem. When the preview monitors stop working, this is indeed a rendering/driver problem, not a problem with Desktop scaling. My apologies.
