Avenue recognises Spout inputs as a source (including the DX 9 Sender) and I can drop Spout on a layer, but the clip plays a blank black screen, or just crashes Avenue in the case of Magic Music Visuals.
I have a Gigabyte P16G, Intel Core I7, DDR 8G x2 with Geforce GTX 960M
No spout input on Avenue 4.6.2
Re: No spout input on Avenue 4.6.2
Could you use the feedback tab found in the preferences to contact us directly with your log file, please?
Alot of spout issues have been solved by reinstalling spout. Give it a download and try.
http://spout.zeal.co/download-software/
Most likely Spout is not using texture sharing. Look at the window of the Spout demo sender to confirm. It will say "Spout Memoryshare Sender".
The machine probably has Optimus graphics which is not set to use the NVIDIA. You can use the NVIDIA control panel to correct this. You can also try the "SpoutDXmode" utility to set to "High Performance".
