I want to dj and vj at the same time with traktor and resolume using a traktor s2 midi dj controller
plz help me
i can use loopbe to duplicate my midi signal to both native instruments traktor and resolume, but the hard part is mixing video and audio in both programs progressively from the same controls
when i turn the browse knob on the traktor s2 controller right or left to scroll up and down my song list selection i would like the same thing to happen in resolume but with clips.
kind of like how you can use the arrow keys on a keyboard to move across one layer activating whatever clip is moved to
for my purposes i would like to move across, either left or right on two layers at the same time but not activate the clips moved to. Maybe preview mode?
then also
To activate the corresponding clips on either layer i would like to press play on either side a or b of the s2 midi controller
Similar to how you can hit enter on a keyboard when a clip is in preview and it will start playing
thoughts ?
let me know.
cheers,
