Pixel mapping issues
Mish
Post by Mish »
I followed the manual page to set up pixel control and I am running into difficulties.
1) currently I cannot output anything to the pixel tape. I set up my lumiverse, a 150 lengthy pixel tape, I assigned it to the composition window and see the levels output in dmx output.
2) then I went to preferences to assign the lumiverse to an artnet address. My pixel controller starts on universe 41 which I believe is Artnet 2:8 or something similar. I press refresh devices and it should be good to go.
But nothing happens. No response. From the same computer in Eos lighting software I can speak to the artnet interface so I do not believe it's a connection problem
One thing of note is that under preferences - dmx output I get no option for artnet to broadcast, unicast, etc. The option isn't there at all. I think the ultimate problem is that resolume isn't actually outputting artnet.
Any help is appreciated. Thanks
Re: Pixel mapping issues
First thing you'll want to do is update to the latest version
SystemD
Post by SystemD »
I have the same project, and it works.
See this topic : viewtopic.php?f=6&t=13885
And my blog : http://divisionpixel.com/configurer-ser ... e-arena-5/
drazkers
Post by drazkers »
Are you sure you clicked output and not input?
If your on the latest version and don't see broadcast or unicast options you clicked input.
I did the same thing this week!
