NYE Countdown auto start
elskin
Post by elskin »
Fairly new to Arena, getting to know it as I go, I've got planned a video countdown for NYE, Audio and Video, problem is I have 3 floors at witch I need to start the countdown simultaneously, can I some how get the video to play at 23:56 (the countdown is 4 minutes long) automatically so I don't have to run like a mad man thought the building to get them all started at the same time.
any help would be amazing
Re: NYE Countdown auto start
if your machines are on the same network, you could start your clip via OSC or Artnet.
elskin
Post by elskin »
Found a solution, not the best but will do, to use Jitbit, and put it on a delayed timer, that way I can still keep an eye making sure its working, unless someone knows how to link it to the system clock, unfortunate they aren't all on the same network
https://www.jitbit.com/macro-recorder/
this one can launch columns tied to the system clock:
http://palffyzoltan.hu/index.php?url=controller/
- set up osc ports correctly in both Controller and Resolume
- create 2 empty columns in your VJ composition, set the playing layer clips to ignore column trigger if you want to keep your content playing
- place your countdown and fireworks videos into the top layer
- save composition in Resolume
- open composition in Controller
- right click on your scenes, and set up the desired launch time for both
- save composition in resolume again.
- VJ as usual
- watch the magic happen.
get the programs at:
http://resolume.com
http://controller.palffyzoltan.hu
lightbx
Post by lightbx »
:geek: :shock: :D ravensc FTW! Best of luck w your NYE setup elskin!
