Hi All,
i had all my clip working before and some reason non of them are triggering now (when i click onit it just shows blue loading bar, i can preview all my clips but it wont play in output window (bottom preview window nothing on top output window)), i been having this issue since i used APC midi with it. any help is appreciated, thank you.
none of the clips are triggering any more
Re: none of the clips are triggering any more
Turn off Midi Clock Input for your midi device. This will make the BPM clock start running again.
While you're at it, you might as well turn off the beat snap (Composition > Beat Snap > None), because what you're seeing is not a loading bar
