Intensity Shuttle Thunderbolt Troubles
gorri012
Post by gorri012 »
Dear resolume team and all of you
First I want to wish you all a happy new year and that everything will work fine.
In my case I have some problems with arena 5.1.2 on OSX El Crapitan with my Mid 2014 MBPro - the last one with NVIDIA Graphics. I run 16 Gigs of Ram and the Intensity Shuttle Thunderbolt. No setupcombination works. In trouble shooting I tried every setup in resolution I could do - I matched the signal provided and read out by my previewmonitor with the settings in resolume, but it didn´t work. I´ve tried to put the signal through my Roland V1HD to have a normed signaloutput but the screen was black in resolume.
Then I tried different drivers:
First of all the 10.8.4 - the new one
and then from the beginning up:
10.1.1
10.1.4
10.3.1
10.3.7
10.4.2
10.7
I never got a signal - always black - tried of corse the different settings in the driver and matched in resolume - all combinations. No luck.
I´ve tried the workflow even with a replacement Shuttle form a friend of mine. very depressing...
The good news is, that the setup worked fine a year ago on this machine. Is this an El Crapitan Issue? Should I grade up to Sierra?
Does anybody had the same issue?
what about alternative hardware? Does the aja Io works fine with resolume? In the end of january I have a very important gig where I need a live cam solution with running through resolume. I hope that there is a solution.
And yes, a few days ago I sent this issue with the feedbackfunction in resolume directly to the team - no answer yet - but I want to sleep well again and hope for help soon :)
Best regards and again all the best for 2017.
Re: Intensity Shuttle Thunderbolt Troubles
do you have a clean preview in Media Express?
