Hi !
I know that a WXGA (1280x800) (16:10 format) is possible over SDI, but not SMPTE-compliant. I would like to know if anyone tested ANY converter that would work with this resolution. I guess BlackMagic Design converter won't work since they tend to be SMPTE-compliant only devices.
Thank you !
HDMI to SDI, SDI to HDMI in WXGA
Re: HDMI to SDI, SDI to HDMI in WXGA
Had some real good feedback about this one from roland:
https://proav.roland.com/global/products/vc-1-sc/
Sam
- HacPRO (Win10/OSX10.13 Render+Mediaserver)
- i9 9900K OC - 64Gb RAM - NVIDIA Titan Xp 12 GB VRAM
- MBP 2018 15" - Livid Ohm RGB - Arturia BeatstepPro - DJTT Midifighter Twister
- Bome MTP - Vezér
Hi WSimard! Did you try out the Roland VC-1, or find a device to do it? I need to send WXGA over SDI as well, just not seeing a lot of options to do it.wsimard wrote:Hi !
Thank you !
