high resolution
shamushu
high resolution
Post by shamushu »
Hi, im new to resolume..Im working on a show that i need to use a high resolution..let say 5244 x 3813 px..is it possible? im using resolume arena 5, mac pro and 4k monitor display.
Any help would be much appreciated :'D
Re: high resolution
Yes but the results will depends on various factors such as GPU/number of outputs and the number of layers/clips/effects you'll be using in your comp.
Re: high resolution
Exactly what Okatown said. I tried this config on my MBP and was getting 6fps on a single output only playing back the built in test card lol
I would suggest a beefy GPU!
shamushu
Re: high resolution
Post by shamushu »
thanks.
Another question. how to get a 4k output.im using arena 5, macpro, rgblink venus x3, moshi mini displayport to HDMI Adapter (4k) but still the graphic is pixalated.
the resolution is 5200 x 3840px.
Please.Help.
