Set/Get numeric value of transition
MRmP
Post by MRmP »
Often I have the need to set or get the numeric value of a layers transition, Currently I can only find this info in the Resolume Project file, are there any easier and better way to get/set this?
Re: Set/Get numeric value of transition
I'd suggest using OSC.
https://resolume.com/manual/en/r5/contr ... ontrol_osc
You can get the actual value by listening for the correct OSC address on composition open, and when they are adjusted in Resolume.
Are you talking about the transition time or the transition type?
MRmP
Post by MRmP »
Transition time.
