Showing content from web browser in Resolume?
gpvillamil
Post by gpvillamil »
So we have a 5 projector setup in a room (3 walls, floor and ceiling) which we use for immersive presentations.
We're using Resolume Arena 5 to manage the mapping (the room is small so the angles are aggressive) and edge blending.
For Resolume-based shows and presentations, it works great. However, there is a lot of interest in being able to project content from other apps through the Resolume mapping, eg bring up a web page in a browser.
Is there any good way of doing this? I'm thinking perhaps through Spout or Syphon?
Alternatively - is there a good hardware based keystoning/edge blending solution?
theLABVisuals
Re: Showing content from web browser in Resolume?
Post by theLABVisuals »
Under MacOS i'd definitely take a look at Syphoner.
http://www.sigmasix.ch/syphoner/
Empyfree
Post by Empyfree »
I'd look at capture card options, you can then manage the content externally and load the capture card wherever you want to in the composition. I use this to bring in "tweetwall" type content along with cameras and Powerpoint content.
gpvillamil
Thank you, this worked extremely well. We added a Blackmagic Decklink Mini Recorder to our rig, and presenters connect their laptop to it just as if it was a projector.
Empyfree wrote:I'd look at capture card options, you can then manage the content externally and load the capture card wherever you want to in the composition. I use this to bring in "tweetwall" type content along with cameras and Powerpoint content.
