Multiple poly slices
Krikk
Post by Krikk »
Hello guys!
It would be great, if we could move together the common points (which are snapped) of more poligons at the same time. Would be quite a time saver in some situation.s
If it's already an option, pls tell me where can I find it...
Thanks a lot, keep it real!
Re: Multiple poly slices
This is unfortunately not an option. It is a very good idea though.
Anothertom
Post by Anothertom »
Isn't it possible to select multiple points by holding shift or by clicking and dragging over a selection?
Of course, if it did this automatically half the time it would be really useful, and sometimes really annoying.
No, in Edit Points mode, your scope is limited to the selected slice.
Yes, I see this happening more as an option to link and unlink specific sets of points, not an automagic feature
