The project file is missing
Resolume Arena 5.01 There was such a failure, All the project files are missing! how to solve this problem?
Re: The project file is missing
First update to the most current version of Resolume which is 5.1.3 and make sure your composition(s) is/are saved in the Resolume Arena 5/Compositions folder and not on a removable drive.
Then, follow the instructions in the Resolume Support page under "Oh no! Resolume won't start anymore!"
If that doesn't work, contact the folks at Resolume directly using mail@resolume.com
