I have updated to 4.6.5 but I still have the same problem of having no control over audio levels. I can't see any preferences/settings where I can choose to have AV controls. When I open the example/demo composition resolume still opens with only a V - video opacity control fader/slider and no separate audio control so I can't see that this is an issue with my files. Image attached.
Hopefully I am just being dense and there is a button to press but I can't find any instructions on the forum or in the manual to indicate this. Any help will be appreciated.
Arena: No Audio or AV sliders showing in layers section. Only one big V slider for opacity?
Re: Arena: No Audio or AV sliders showing in layers section. Only one big V slider for opacity?
View > Show Audio Controls
Doh!!!
Thank you
I will now go and hide in a cave for a week and repeatedly chant 'must search every menu option, must click every menu option.....'
Thank you
Whenever you're lost, a good trick is also deleting the config.xml file. This will force Resolume to start with the default comp and default preferences.
