Hi, pls help.)
Win 10, 2x msi gtx 1080 ek x, no sli, ssd, dxv..
Clean comp, new one, no other soft, latest quicktime, drivers etc..
When click to advanced output, resolume stop everything, black screens all of them, just 3 connected displays.
One monitor via dvi, one hdmi same grafic card, second hdmi second grafic card.
Res 1920/1080, six layers, bypass solo, no composition.
All displays same res, 1920/1080, one at 60Hz, two at 30Hz.
Hdmi splitter connected first, then to displays (using monitors in foh to avoid win 10 display bug)
When black, not showing fps. Need to reload saved advanced output to get back again.
Any idea?
Thx
Arena freeze/black when switch to advanced output
Re: Arena freeze/black when switch to advanced output
Pc power supply via ups.
Happens only if opening "new" adv output, if one isnt saved and closed than works fine, but if saved, closed and reopen as new, than freeze/black..
just going to do, not having the same setup, hopefully its gonna help, will post result for sure, ty
So I think there is no Nahimic on my pc. But there is new Vulkan API.
Now I have one monitor and one TV, each in different g card, no problems with adv. out at all.
Maybe the splitters (cheap)?
Or Vulkan? ( Vulcan run time libraries)
