Hi guys! Im new to Resolume Arena. Currently studying Resolume Arena 5.
I had bougth some extra cheap projector just to train myself in vjing.
But there is some issue with output video: when I turn on display 2 in Resolume, there is nothing happening, the picture is same (desktop wallpaper). But when I click on windowed mode it works properly.
Maybe it is not a problem, I just can not find some usable settings.
Any help guys? Thanks!
Problem with output
Re: Problem with output
This sounds like you are running into a known problem with Optimus graphic switching. It's described in greater detail here: viewtopic.php?f=12&t=13529&start=20#p57494
Long story short, you're experiencing what we consider a bug in Optimus, and you have to wait for a Windows update to fix it.
There are a few workarounds floating around: viewtopic.php?f=12&t=13763&p=58381&hilit=optimus#p56997
Thanks bro! Probably i will wait for update. Hope they fix this. Thanks a lot. Close the topic
