Number of CPUs?
alexan07
Number of CPUs?
Post by alexan07 »
What's the max number of CPU Resolume can take advantage of? Is there a point of diminishing returns?
Re: Number of CPUs?
I would say 1 cpu, 2cores. unless you plan to run converting in the background, or you are not using dxv.
I never saw resolume above 100% cpu load with dxv.
Playing h264, the decoding happens on the cpu, so you could see a benefit of more cores there.
