I'm looking for something that I can just rock up to a DJ set with an project on to the wall or ceiling or whatever.
Anyone got any suggestions of what I can look in to?
Best, brightest, smallest, cheapest short throw projector?
roryclewlow
Re: Best, brightest, smallest, cheapest short throw projector?
I've been using an Optoma w316st, 3600 lumen, wxga 1280x800.
20,000:1 contrast. From the research I did on projector central and so forth was the brightest in short throw area before you break through to more pro projectors with separate lenses and much higher costs.
£500/600
Had it around three metres from wall.
DACHHU
£500/600
DACHHU
I use an NEC NP-M352WS. I think its discontinued. 3500 lumen, 1200x800 SXGA. I figure the best you will get in the short throw field is around 3000-3500 lumens, 1280x800, before you go over $1k.
I have a good amount of experience with the Optoma short throw models too and put simply, they deliver. Should be fine for what you need and then some!
roryclewlow
Awesome! Thanks guys
