Please Help for this MIDI problem
Computer :
OSX10.8.5 MBP I7 16Go SSD
videos on external FW800HD
Resolume Avenue 4.6.4 rev56521
All my softwares are registered, no crack !
Composition :
Full HD videos 1920x1080 last DXV3 encoded (no alpha)
Only 1 layer ! no effect on clips (at the moment)
I'm sending external MIDI notes from Ableton Live to Resolume from IAC Driver n°1
I'm sending sync from Ableton Live to Resolume from IAC Driver n°2
I've got also some controls coming from Ableton Live to Resolume from IAC Driver n°3
Issue :
sometimes Resolume doesn't take the note sent, not always the same, sometimes not, but often it looses one note ! really annoying, black screen for my audiovisual concept ...
What I'm sure :
I can see all the notes (1 per 30sec max...) sent by Ableton on the IAC driver n°1 with MIDI Monitor, no problem for sending from Live, I've got a spy with MIDI Monitor too and they're recieved by the IAC driver
No controller attached at the moment to be sure there is no more MIDI or SYSEX message
What I want to know :
Does anyone have lost some MIDI notes sent ?
Is there any MIDI problem in this new version of Resolume ?
To go further :
I can't use a previous version of Resolume because of my DXV (last) encoding ...
If I want to encode all again (...) with a previous DXV codec, will I see all versions of this Codec in Premiere for example ?
Many thanks for reading and helping if possible
SOLVED - MIDI IN glitch ?
Re: MIDI IN glitch ?
Wht happens when you try the same setup with resolume 5?
Also why are you using so many iac links? Why not everything over one? Are you maxing out your channel count?
Thanks for answering
I'm on Avenue only 4 is avalaible
I've just tested tu use only one IAC, same problem, random moment ...
I've tested also to use only notes, no sync and use Resolume BPM ... same ...
I've used several IAC to try to clear the signal for Resolume
Re: SOLVED - MIDI IN glitch ?
SOLVED
the pref xml files didn't update my changes about the IAC driver busses
all works like a charm, thanks to all !
